Is that based on experience in your old Rex or the GTR when you first got it? Either way, thanks...often thought about Hawk pads but very little feedback on them from Skyline owners :D
That is the current set up on the GT-R. I also used Hawk blues on the Sti with some race brake comp 9's on the back.
Regards
Andrew
  • Replies 75
Most of our drivers are trained to trail brake, so we use HT10's front and rear. You won't find any problem getting them up to temperature in a lap dash/super sprint environment. In half a lap warm up we see well over 300 degrees at the rotor (we have infrared temp measurement).
Ok, you have the cool toys :D
Good to see they actually work after a lap or two. The guys here in the Vic WRX club were having issues and went back to the Blues.
It seems the blues are getting harder to come by in the AP 6 pot pattern as well...
Regards
Andrew
Edited by BBGTR
It's cold in Mexico :)
and they really need to learn how to warm up the brakes as well as the tyres :O
:blink: Cheers :w00t:
BBBWWWHAHAHAHA. I'll pass that on to some of the errm, bigger less articulate blokes for a reponse :worship:
Well, im hoping the Porsche GT3 6 pot calipers come through for me, but another option i have looked into in is the new Corvette 6 pot caliper with some 343-355 x 32 mm brake rotors, initial numbers have it coming in at around $2500
So either these or the Porsche brakes will do me just fine
I'm after a brake upgrade too. My local track is symmonds planes, and our super sprints go for 4 hot laps at a time.
I currantly have standard disks and calipers, with bendex ultimate pads, and castrol srf. But by the end of day i have no brakes. Performance wise my brakes are fine at the start of the day, I just want them to last. I was thinking of putting bigger groved disks on, putting some braded lines in, and rigging up some ducting for the brakes.
any help would be great.
Start with some proper pads & fresh brake fluid (Dot 4-600). The discs aren't the problem unless they are under thickness, warped or grooved.
Ducting is a good idea. So is one of those Cusco brake stoppers as the R32 firewall flexes an unnerving amount under load.
Depending on how hard you mash the brakes, the braided brake lines aren't a necessity. They may make the pedal feel harder, but don't help you stop better to any real degree unless you are boiling the brake fluid which you shouldn't be.
SP looks to have some very big stops. Ok it has some nice long straights to cool them back down so with ducting i would be hopeful you could keep pad and rotor temps under control.
But at the end of the day, with GTRs that have more grunt then std..say over 250rwkws, you typically are tryign to stop 1600kgs of fluids/steel and driver...so 296mm rotors may not always be enough.
HAs anyone actually had success from running tweaked std brakes on modded R32 GTRs at the track? Just about every GTR driver says they struggle for brakes..the GTSTs with similar brakes, l;ess weight and power seem to handle track work a lot better
my car currantly has 226 rwkw, but i have hks 2530's going on soon, so i will should easy have 250rwkw.
SP has 2 very big stops, and one moderate one. I'm doing about 170-180 going into hairpin, braking a 150m down to about 40-50. Then up the back straight i get to about 200-210, at the 200m mark down to about 80-90. Then From the top of 3rd gear down to about 80-90 for the first corner. All of that in 1:06.
From reading the thread, I got the idea that spending big money on brakes wasn't realy needed. But i'm getting the fealing SP demands a bit more money spent on brakes.
Any kit recomendations? A guy that was there on the weekend in a GTR had just installed a $4300 AP racing kit (6 pot fronts, 2 peice groved rotors, and all the screws and shit), i'm not keen on spending that much if i don't need it.
Ducting would be the first place to start...then some temp indicating paint for the next visit. See if you can an idea of the temps you are reachoing and make sure your pad is good for it, and your fluid is top shelf. You may find your ok...
Yeh, i suspect SP is a bit like Sandown, good fun but hard on brakes and engien temps because of the tiem you spend on the brakes slowing the thing and the time you spend on the throttle belting back up through the gears.
Best bang for buck which doesnt involve custom gear, would have to be the CSC 343mm 4 pot kit. It will fit inside 17" wheels (well it fitted inside my WEDS but not AVS) and has a nice 343 x 32mm rotor and uses Porsche pads, so plebty of pad compounds available. For abotu $2800 including some street pads its about the best bolt on kit i know of. Sell your std brakes and rotors for $500-400 inc rotors to an S13 lad and they look to be good value.
The Production R32GTR N1 runs the standard Brembos with DBA rotors, AP600 fluid, braided lines and Hawk pads. No problems in a 1 hour race at Bathurst, 2 hour race at Oran Park or 1 hour race at Eastern Creek. It won all of those races by the way.
Does that count?
:D cheers :)
PS; Obviously it's full weight, no lightening what so ever is allowed and the driver is not light.
Does that count?
:D cheers :)
Thats an R32 with R33 GTR brakes though isnt it? 324mm rotors. So its a healthy step up from 296mm, and would i be correct in saying that it would not have as much power as many ppl street GTR????
Slightly different Brembos on the R33GTR's, but close enough.
The engine is full N1 spec, blue printed very carefully, N1 turbos, no cat, race exhaust etc
ECU is free, hence it has a Motec
So the power is ample (or in RR terms, "adequate")
The trick is it goes around corners very well, so it doesn't use the brakes as much as some.
The Improved Production GTR actually has less power due to the turbo restrictors
But it is lighter and has more suspension mods, so it ultimately does quicker lap times
But not because of power, it simply goes around the corners even faster
The reality is I think State Championship level racing puts more emphasis on braking performance than a lap dash, super sprint, hillclimb or social track day. Keeping those persky Evo's out under brakes for 1/2 an hour requires some braking performance.
:D cheers :)
...ok.
LOL, one last question, dotn know how relevant it is to GTRs etc though. What are your experiences with these cars at Sandown, and or Symmonds Plains? I know for instance Sandown is much harder on my cars brakes then say Eastern Creek or Oran Park ever where??
Massively off topic BUT SK that High Energy sump u have in ur sig, is that the bees knees? i.e what i should be looking for? i was going to get on of fitz's sump adapters and a trust enlarged kit, or is one of them High Energy ones better?
I haven’t been interstate racing with the GTR’s, but Sandown certainly was no harder on brakes with the RX7. It runs very high brake temps at 2 spots on the circuit at Sandown but Oran Park has 3 very high spots and Eastern Creek has 2 highs and 2 very highs. Oran Park is the highest brake wear circuit.
You can certainly see the brake temps drop as you increase the corner speed. I really believe that’s the secret. You only have to look at the lap times, there are 600+bhp highly modified Skylines that are 5 seconds a lap slower than the Production GTR. It isn’t straight line speed, it’s all in the corners. That means the brakes work harder to get the higher straightline terminal speed down to the lower cornering speed.
The bottom line, as I always say, spend the $6K on suspension and driving lessons. You will do a faster lap time than spending the same $6K on brakes.
:dry: cheers :thumbsup:
PS; the High Energy sump currently in the sig. is the best off the shelf solution I have found for a 2wd. Obviously they won’t fit a 4wd, the Performance Metalcraft sump is the best for them.
Edited by Sydneykid
Have you had the CSC's before Troy??
Me? Nope. But have spoken to a few of the WRX guys and a Commodore guy that runs them. He has 320rwkws in his HSV and the thing would weigh about, what 1750kg? So if he is happy.
I did have them all trial fitted to my car...i decided to do my own setup which is what you saw sitting on the loungeroom floor :dry:
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
