Hi All,
Anyone know where i can get my rb25det injectors hi flowed to about 500cc?
any idea on price?
thanks
You may be better off buying top feed 14mm injectors and making a fuel rail to suit. Not that big of a job really if you have the tools available. I have heard bad things about high flowing injectors has anyone else?
Hi All,
any idea on price?
thanks
Why not replace them? If you want around 500cc there are a lot of choice and they aren't hat expensive and they will drop straight in...maybe needing collars if you go for the sards.
Nengun sell all brands delivered to your door -
HKS 550cc $158 ea
Sard 550cc $710 all up
Nismo 555cc $161 ea.
Not sure what the price would be on the hi flowing of your stock injectors, but for the price difference and flow reliability I would be replacing them
Cheers
JB
i would go for real injectors, but i dont have the money....
i remember reading somewhere that u can highflow your injectors for $50 each, which are flow tested and show that they are as they say...
As long as they are reliable then $50 each is a good price...check these threads out from others asking about high flowing previously.
Link 1
Link 2
Hope some of the info helps :D
Cheers
JB
Link 1
Link 2
Hope some of the info helps :rofl:
Cheers
JB
Thoses threads still dont clear things up for me. Anyone using highflow injectors with a power fc if so what cc and how long have you been running them for.
cheers
Do a search - there is a known place in Melbourne that do it (AVE?? or something similar, cant quite remeber)... they flow them to 500-550cc, for around $450-$500 I believe
There is a reason why high flowed side feed injectors are not all that common. It's cost comparison, they simply aren’t that good a value for money. Cleaning, high flowing and testing side feed injectors costs around $80 each, say $500 for a set of 6 including freight. You can buy a new set for ~$700, so it’s only a $200 saving. Which you can quickly recoup when you sell the car with the standard injectors in it and sell the aftermarket injectors for almost what you paid for them. Brand name aftermarket side feed injectors hold their value very well.
:thumbsup: cheers :)
PS; be careful with the SARD side feed injectors, they are actually designed for 1JZ/2JZ and therefore need adaptor collars to fit Nissans
But are they any good SK??
I got a set really cheap, Now I am worried that they will cause issues :S
got mine hi flowed by avo here in melbourne , it cost $370 for all six. had them in for 2 years now and ive got over 300rwkws. car idles fine and hasnt missed a beat since.theyve got a website.
what size did u flow them 2?
sounds good big carl certainly something to consittor if you are on a budget
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
