  • Replies 504
i mean umm don't get me wrong guys.. skylines are great.. but why did they change touring cars from turbos to v8's????
yeah thats right
*dons flame suit and runs out* muahah
Lol..dont think your flame suit can protect you from shotgun pellets!
They changed touring cars from turbos to v8s so the v8s can start having a chance at winning!:P
Makes me wonder though if a NSX-R can beat those v8 touring cars..
I owned a V8 Commodore.
Cost me close to 5k in repair bills within 9months of owning it.
First.. Subframe cracked where the diff mounts up (IRS)
Second.. Gearbox bearings died
Third.. LSD Diff openwheeling and grinding really bad.
So my nice 'solid' lol commodore was not so solid after all, for a daily cruiser yes maybe, if I could put up with the rattles. But as a car that will handle a bit of a hammering, no. >_<
I freaked the first time I jacked the commodore up, opened the drivers door to grab the phone went to close the door and noticed my nice 'solid' commodore's door wouldn't close as the whole body twists when the car is jacked up. It was literally a good 5cm's out. :S
Talk about a solid chassis. No wonder those things split in 2 in high speed accident. :P
I've owned one so I can pay out on them. :)
Touring cars where changed for all the Ford and Holden fans to have a sport where drinking and lack of intelligence is encouraged over a very long day, which BTW finished quicker when the skylines where racing :laugh: .
If Holden and Ford aren't so scared why did they knock back Toyota from entering the V8 supercars?
Because they know even a fridge on wheels will kick their ARSSSSSS!
Edited by fuzzy_scuz
AHYES.
hahaha....gold
where's ash these days?
he's around. we just went down to melbourne last weekend and he ended up buying a track car. a '71 Torana LC. who would have thought the drag boy would go circuit ay.
hey dave, your sig reminds me of your poor little car being written off. if i remember correctly you wrote that in shortly after when you had the shits with cars...?
so he has a car that can turn corners now? he must be growing up!!! haha
does he still have the drag car?
yeah, very shortly after i had the shits with cars...that didn't last too long, now i'm having a very hard time just trying to not sell my golf and buy something stupid
how's the 240?
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
