This is my new burnout/thrash car. It is car number 8.
However this one is the best out of them all. Its got the works, custom paint job, stickers and its even TYPE R.
Check it out
http://members.ozzienet.net/~ozmac/Honda/
Bare with me until I get the videos all uploaded.
Its well worth the wait :D
More to come :D
When you finally decide to come visit me Dan, i'll take you for a spin.
Did you take a look at the videos?
I'm going to get a decent gallery going and get some better outside footage.
My head is sore from hitting the roof over every bump :)
Yeah, it was time for the old line to move over to something new.
bwahah!
this brings back some very fond memories of my friends bucks party...
what do you get when you get 10 or so guys with $100 odd bucks each, a telephone, a trading post, a big paddock on a farm, spray paint, some tools & helmets???
a farken great time :)
we ended up buying 4 shitters at an average of about $200 each...at the end of our rally day, we thought we'd see which car was the strongest and the honda won :D the engine wouldnt die, the meteor was the quickest around the track but the engine caught on fire, the commodore ran out of petrol and the corona blew its radiator...
:D
Haha....
Just you guys wait.. Theres more pictures to come.
I wish i had pictures from my previous cars.
This honda civic is pretty hard to kill.
I'll get a decent gallery happening with some outside shots of our rally track.
For those with a decent connection, i recommend downloading the videos. They are deffently a good laugh!! :)
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
