  • Replies 403
yeah same kit but not lower... i meant urs was lower and with better wheels :)
hopefully i get it before it sells... its gold... then all we would need is a bronze coloured one for the full medal count :)
well got a pic from todays 4 door cruise, and a new dyno sheet as of friday so post it up to
mods are
Internally standard Rb20det
Garrett dual ball bearing 450hp turbo (same as a gcg hiflow, this is using a 33 comp cover)
RB26 PFC modded to fit RB20
Walbro 500hp fuel pump
Splitfire coilpacks
FMIC - cheapo
catback tanabe exhaust, punched out cat, standard front pipe/dump pipe
standard afm, injectors
running 11psi on turbosmart t-boost due to nearly maxing out injectors
soon to have front pipe and dump pipe, z32, 550cc inj and 18psi
Yeh was ment to write that to but forgot, was gona get one cause i know how restrictive the dump/front pipes are
The front dump pipe and high flow cat can add 20-30kw, not sure about the hollow cat though whether it is more efficent than a high flow? ($$$ if you get caught).
BATMBL often has group buys on here and Just Jap have one too. Worth getting with the work you have had done.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
