Hey all,
I've read that the wastegate actuator off stock R32 turbos are set to allow 10psi from factory. Thus it being a fairly accurate and good way to get 10psi on an R33 turbo.
Just wondering if the same actuator can be fitted to an R34 turbo though? I'm fairly sure it can be as I believe the only difference between the R33 and R34 stock turbos is the compressor wheel being nylon on the R34 as opossed to.. can't remember what it was on the R33.
Also, it'd be hard pressed for an actuator to stuff up right? Perhaps before installation it can be 're-conditioned' or something along the same lines? Perhaps by cleaning the thing or lubricating the rod or something?
All answers will be greatly appreciated. :O
Thanks,
Andy
actuators can stuff up they can either get stuck shut or they become loose over time and dont hold boost. the easy way to check for this is when the actuator is off the turbo pull on the rod, if it is very easy to move them more than likley it wont hold boost.
All of the R33, R34 and VG30 actuators i've felt are very easy to pull open.
The R32 items on the other hand... my actuator has cloced over 200,000km's and its still 'almost' impossible to lift off its seat.
Actuators almost never stuff up, so I wouldn't let that worry you. :P
Do remember you can buy brand new adjustable actuators for around $120-$130. They can be purchased in a variety of base pressures from low 6-7psi right up to 17psi or so.
Unless the comp cover has been rotated the actuator 100% does fit.
I have had an R34 turbo in my grubby hands along side my vg30det and rb20det turbo.
The actuators weren't fiddled with unlike your 'r32 spec' one. I'm asusming they welded it in the incorrect position or when assembling the turbo the comp cover was slightly rotated causing the positioning to be slightly out.
The only actuator that wasn't an easy fit was the vg30det actuator as its arm is almost straight vs the rb's kinked. This is due to the comp cover being positioned differently. Its well known when fitting a vg30det turbo to an rb you must rotate the comp cover. As a result the stock vg30det actuator has fouling issues and you must use either an R32,r33 or r34 actuator.
I'd say something funky was done with your actuator/arm or something Alex, 100% I can confirm the actuators look identical and bolt up exactly the same, The ONLY difference is the spring inside.
I've even ran the R34 actuator on my vg30det turbo as I was fiddling.
EDIT:
I've attached a pic of the R34 turbo with its actuator fitted. Any one who has had their R32 or R33 turbo will quickly see that the actuator is principly the same.
I do remember a slight difference. The nipple on the diaphram housing thingo. The R32 item stems off the side where as the R34 item comes out the top and does a 90degree' bend. As can be seen in the pic, obviously this doesn't affect anything.
I ripped apart the turbo checked it out measured everything and cleaned it up.
I've mentioned prior that the R34 turbo runs the larger OP6 VG30DET turbine housing, same usual RB turbine wheel mated to the 'plastic' compressor wheel.
Essentially the R34 turbo is identical to the R33 Series 2 turbo but with the slightly larger turbine housing.
I assume Nissan dropped the larger turbine housing on the R34 as its more efficient NEO engine spooled up the previous model turbo a little too early + the larger turbine housing = less back pressure that results in improved VE at high rpm, improved VE = more peak power.
As we know the Neo does indeed make a health 206kw vs the R33's 187kw. So a little turbo tweak + the more efficient neo head see's more power. :wave:
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
