  • Replies 83
i know i saw it somewhere. i will sus it out and let you know. the only skyline i've heard that wouldn't be over the db rating would be my mates. it has a 3" jasma with the double muffler. it has a center resonater and the rear muffler is an oval muffler. it goes into the muffler as 1 pipe, then in the muffler it splits into 2 pipes then comes back out as one. basically like an overtaking line on a road but with a wall down the center.
mines pretty quiet...
Neighbours dont have to much of an issue with it :D
JustJap/Steve,
Can I get an idea of how many dB the full turbo back xforce exhaust is? Have you guys done any tests on ones you've installed??
Anyone actually - wondering whether it'd still be "legal" - 90dB (i believe) in NSW..
might go get one done on the weekend. father in law works at an exhaust shop. will do a test with silencer in and out. i have split dump, 3" front pipe and cat, 3.5" x-force cat back and muffler is 3" x-force cannon. still has center muffler. i know it is supposed to be legal but i really doubt it. my father in law's falcon has a standard 2.5" sports system with both mufflers and it is quieter than mine and his is on the limit. but the only way to properly test is to do it the ADR way. it is as follows-
cones are placed at a predetermined distance, with a vehicle being accelerated through them at full throttle in a certain gear (usually 3rd). the peak db reading from the meter (a predetermined distance away) is recorded. runs in both directions are done, and a radar gun is used to ensure entry speed is around 55kmh.
a stock xr6 turbo is 87db, and a stock xr6t with just the center muffler removed, but stock piping size only just comes under at 89db.
Cheers guys..
If anyone has the details on it that would be great.. anyone had an sound tests done..
if I get it replaced i'll keep my stock one in case of getting defected
ive heard justin911's car, and i doubt its legal...
mine on the other hand would be :D
  • 3 weeks later...
Ok guys, I have come to a conclusion about the exhaust (after doing some really exhausting research! >_< ).
I have decided to stick with BATMBL r33 split dump/front pipe (s/steel) and the CATCO 3 inch large Cat - about $620. And for the Cat back I have decided to go with the APEX-I Bomber from BT-Revolution - about 750. (havent put the orders in yet though).
Total comes to about $1370 before fitting.
What do y'all think about this? Good combination?
i paid $400 for 3.5" cat back at mates rates. but that was still above cost by a bit. and that the price for the 3". ordered a 3" and got 3.5" at same price.
i have seen the x-force cat back systems on ebay for i think it was $599 for 3" and $699 for 3.5"........or it was $499 and $599....either way there was $100 difference.
im gettin my exhaust from exhaust technology in SA and they are freighting it up to me. (in western syd)
3" straight thru from turbo back with highflow cat (removable) with straight thru pipe to Apexi manual ECV to dual 3" tip.
turbo> 3" dump/front -> removable cat/race pipe->3" pipe ->Apexi ECV-> Dual 3" tip :D
think its $1400 to my door.. ill heatwrap it then install it myself in about 30 mins :D
stainless steal :ermm:
Edited by illusiVe
when x-force advertises that theyr exhausts are: "below 90db" or whatever the legal limit is... that is measured with the silencer on I'm pretty sure. It's over the limi without the silencer.
Still good value for money exhaust though! Thats what I'm getting.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
