getting a 2 way might not be that bad. U might have scored a Pro LSD which u can adjust the preload on it....which is the same diff i have :D
How much preload variation can you get on this? Does it use the stock inner C/V joints / stub axles? Can you get alternative ramp angles for it? Was thinking of getting one of those! Cheers
https://www.sau.com.au/forums/topic/118708-nismo-lsd/#findComment-2191520
from memory 4kg, 7kg, and 12kg preload (ie soft medium and hard) Mine uses (in r32 gtst) stock everything. It should come with new stub axle bearings too in a new kit? Im not sure but mine was a complete overhaul done. Only thing is i want a ratio change now so im swapping to a 3.9 r200 shortnose crownwheel and pinion :D
https://www.sau.com.au/forums/topic/118708-nismo-lsd/#findComment-2191558
Thanks for the speedy reply! Are they available in both 1.5 and 2 way? Any idea if the ramp angles are available in alternative configurations for 1.5 way? Cheers.
https://www.sau.com.au/forums/topic/118708-nismo-lsd/#findComment-2191609
I'tll only step out if you want it to ie dont pop the clutch on a down change. If you are braking hard, push the clutch in and hold it (like u normally do)
Ive had to do an emergency brake before (some moron pulled across infront of me, then stopped) and i clutched it and braked at the same time. It stopped like a normal car would.
People seem to worry too much with these diffs....
https://www.sau.com.au/forums/topic/118708-nismo-lsd/#findComment-2193606
dude. take a pic of the damm thing about 3inches away from the whole!!!
i cant see shit in that photo. :starwars:
like phatr32's pic kthanx
whats this diff (its in the front of our GTR)
sorry for the lame pic...its the best i could do
https://www.sau.com.au/forums/topic/118708-nismo-lsd/#findComment-2198381
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
