  • Replies 54
Posted Images
i thought that type of engine went in the early R32 GTS? not in a 96 model R33 series II
R33's were offered as a bottom of the barrel rb20e
YanG = judging by your thread's name, if you bought the car advertised as a non turbo RB25DE, then you've been seriously mislead.
An rb25de should look something along the lines of the rb25det, without the turbo obviously
https://www.sau.com.au/forums/topic/118749-is-this-rb25de/#findComment-2186372
I hope for your sake you weren't misled and paid according to RB25 pricing...
EDIT: No offence, but don't people research what their buying these days? Do they just go out, fork out the cash, take it home, then ask questions, ie. Can you drive this object I just bought? Does it have wheels? What is the steering wheel for?...
Edited by ToF
https://www.sau.com.au/forums/topic/118749-is-this-rb25de/#findComment-2186637
are there rims? suspension? bodykit? stereo? that came with the car? how is the overall condition of the car?
i would be trying to get some money back otherwise if it were advertised to you as an RB25DE.
depending on overall condition + mods, i'd say you paid abt 1-2g more than you should have.
https://www.sau.com.au/forums/topic/118749-is-this-rb25de/#findComment-2187006
got a pic of the rest of the car?
This car come with 17inch rim, year 1996, alpine sound system 300kw, one sub-woofer, factory sun roof, RWC, 1 year reg till 2007 apr, and 2 immobilizer for 12,000.
The owner also offer me that 11,000 without any sound system. but i choce with the sound system. Then i paid 12,000 to him.
Am i really made a very bad deal?
https://www.sau.com.au/forums/topic/118749-is-this-rb25de/#findComment-2187119
actually. thats pretty good, and the factory sunroof etc except for the engine thats pretty good. just dont try and race anyone with it... and the money you save on petrol you can put towards a rb26 conversion :)
you on your Ps?
oh you also didnt say if the seller told you it was a rb25de?
https://www.sau.com.au/forums/topic/118749-is-this-rb25de/#findComment-2187145
you on your Ps?
what mean with Ps ? sorry, i was a noob for this forum, just join.
yea.. The owner didn't said that. Cause this is the first time i bought the car by myself, have none of the knowledge. So it was the experience to be paid if there is a loss.
May i ask one more question? =p if convert to RB26 will be cost how much with the labour wages?
Thanks Alot to you guys.. i get my answer here.
https://www.sau.com.au/forums/topic/118749-is-this-rb25de/#findComment-2187172
actually. thats pretty good, and the factory sunroof etc except for the engine thats pretty good. just dont try and race anyone with it... and the money you save on petrol you can put towards a rb26 conversion :D
you on your Ps?
yea.. firstly i thought 1996 skyline will always come with rb25de or rb25e. is that true? cause the previous owner told me that it born at 1996.
https://www.sau.com.au/forums/topic/118749-is-this-rb25de/#findComment-2187202
dont bother with rb26 conversion just yet..
Just put a stock rb25det engine in there. Thats what that car was built for.. or rb25de..
But it will cost anywhere between 3-5k-6k includin labour n all..
Hmm if you were mislead take it back and try and get a refund!!
https://www.sau.com.au/forums/topic/118749-is-this-rb25de/#findComment-2187203
Ps-means license type..
You live in aus lol??
:D aha.. yea, still on Ps. haha.
Last time i asked the owner, and he just answer me "Don't know" then i didn't ask more about that. and i was lack of knowledge for skyline. Just compare to this kind of skyline with other, and found out it was cheaper, but dunno there was a different for the engine. it's was my big big mistake. I think i can't take any refund on it, under the business law. Any suggestion? siddr20? thanks for answer my post. =)
https://www.sau.com.au/forums/topic/118749-is-this-rb25de/#findComment-2187223
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
