  • Replies 111
Posted Images
just read all that, tofu u had some bad luck there!
know how u feel though, when i got my car had to take it back to dealership like i dotn how many times to fix sh*t but they never did what he was meant to fix.
so ive had to fix heaps of it, kinda looks a bit dodgy coz had to get new rims coz the ones that came on the car werent good, so now my cars like hell high of the ground!
some of the damage was my fault when i had a lil accident
but i feel ya tofu!
engine work? yeah a little bit.
I did end up having enough time to get to the pits so it will br tomorrow norning. Did get a dyno on it and it hit 275 bhp @ 7500 . Im a little dissapointed with the result as there is quit a lull from what i can see there is a remapping issue *sigh* another thing on the to do list. lols
  • 3 weeks later...
Well its been a while since I have updated the progress on the struggle with the car.
About two weeks ago, after nearly having a break down with the shit that had been completed, need replacing and what need doing I approached an associate at JShop and asked for a huge favor. An expensive favor (sanity or money ???).But at the rate that i was attempting to get it licensed I was happy to spend the money getting a professional to finish the job.
So many issues have been brought to attention since its purchase and I am currently seeking some legal advice as there were a few serious concerns and neglect in the sale that were raised:
1. Car was sold with no front intrusion bar.
2. The only seatbelts that were fitted to the car were incorrect, the rear seat belts were used for the front and not attached correctly.
3. The diff was a stock diff, poorly weilded into a lock diff. This would of caused the issue with the wheel falling off.
Not really wanting to go into details about it but I am looking for the cost of repairs and replacement for the rims.
Well JShop has put nothing but there best effort into the car and after a week of hope they took the car to the pits early this afternoon. Well I get a call from them at around 4pm "the car broke down at the pits." Not on the way, at the pits. Come on guys, who can say this has happened to them. It seems to be electrical so hopefully Monday/Tuesday is the way to go.
Rim shopping monday, nice set of 17/18s with 3" of dish. *bling*
god damn andrew..
what caused it to break down?
not having the best of luck with this car are you!
hopefully it passes over next week, i want to see this thing out on the road, with number plates, and 4 wheels..
Nope, it was the kill switch going faulty and now that have been removed.
Well it failed the pits. The two big things:
1. Bent Chasis Rods.
2. All the boot racks need replacing
Another week at most but most likely another 2K in repairs will go towards the car.
Edited by Tofu
*sigh* yeah, seems like it hey.
Well before work I just dropped the car off to the Panel Beaters to have the rails replaced and it seems like its not just the rails that are bent. :D:P
This is just unbelievable lol
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
