Hey guys, my mats car just came from the compliance workshop and the nite after was stolen from his driveway between 1am and 8 am in Auldana.
Its a White 1988 GT twin turbo supra. With White rims, and the sideskirts have a small piece missing on both sides.It aslo has Twin turbo stickers on both sides of the car.
If anyone knows anythin about this, or sees the car, please cal me on 0411 255 081.
Guys this car was stolen from a very good area. Make sure u dont leave ur cars out so that these same assholes can get it aswell.
Dean
https://www.sau.com.au/forums/topic/11888-stolen-1988-white-supra/
that is completely ****ed. I hate theives and there should be more serious punishments for them when they get caught! :D
Will keep an eye out for the car.
Perhaps it might be a good idea for your mate to take off things like Twin Turbo stickers? Why advertise the fact?
The car came stock with Twin Turbo written on the side. It was something toyota did for some reason. The car had only just come back from Complinace center, so he had no time to put alarm/immobiliser in.
And it was the first time he left the car out. It was an accident, his mum was cleaning the garage, and moved it into the driveway, but forgot to bring it inside for the nite.
Thanks guys
Dean
I know that car u r on about, I met the owner a while back at a servo and said "Nice Ride" So i deffinatly keep and eye out for it.
Sorry to hear about that. Thiefs need the nut suck ripped off by a slow moving tractor. Did the car have a big wing on the back? Just wanna make sure its the same car. Was the guy that owned it an Oriental? no offence. Just wanna make sure im looking for the right car.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
