  • Replies 44
Tomorrow night for those who care - I will be there, Im pretty sure that Jayce, Erica, Mark and Luke will be too mabye even Andrew and Leigh...
I tried a long time ago to strike up some interest with everyone (see S*E*X it aint trivial) but to no avail... So the new plan is - If you want to go then go - if you dont then dont (sit at home and drool like an idiot infront of that so called "TV show" the OC)... Anywho, its up to you!
P.s.... Only the coolest and most dedicated ACT SAU'ers kept going when everyone else bailed, heh heh heh ;)
Edited by Bullet32
https://www.sau.com.au/forums/topic/119029-jerra/page/2/#findComment-2389642
well my smart idea of taking the other means of transport netted me a nice cold that i am still trying to kick so i am out won't be able to make it till the 22nd so see you all then :D
SOFT! :)
Whats with the empty edited posts Beau??
Edited by Bullet32
https://www.sau.com.au/forums/topic/119029-jerra/page/2/#findComment-2392817
Idiot so the Jerra club in Jerra ... gets the street directory out I see I see so trivia night on tuesdays the place to be huh? hmmm might go for a drive tonight and see whats the go
JaiJai,
did you happen to make it out last night? cause at about 7:15pm, a grey R33 with an SAU sticker on the back window cruised through the carpark and left without saying hi. thought it might have been you? :D
https://www.sau.com.au/forums/topic/119029-jerra/page/2/#findComment-2431511
no the evils of work! I will go next tuesday ive got a white r33 with a torn and damaged front bar with a dodgy hybrid intercooler....qld plates
yeah thats what you get learning hot to drift
buuut I will make it out next tuesday Ive got nothing on so hopefully
I'll be able to meet a few of you!
https://www.sau.com.au/forums/topic/119029-jerra/page/2/#findComment-2432457
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
