the USA style ones should fit I reckon? anyone know for sure?
Yeah, I had USA rear and USA Slimline front on my R33.
The USA fits really well where a Jap plate has come out of.
I got the slimline on the front so it didn't hang down in front of the intercooler. Still same width as std slim, but no "dot" between letters and numbers, same as USA full size.
YES YES YES.. go the SAU PLATES!!!
i wouldnt mind a japanese stye plate, then it woudlnt be cutting into my front bumper..
don't quote me on this but a mate told me it was "illegal" to trim your number plate to fit, however you could always bend the edges underneath the plate, supposably this isn't
trimming and bending are both defectable!
no they arent :)
Mate works for DOTARS and has trimmed his numberplate, letterbox style. As long as all the numbers and letters are complete, its legit.
Defect station guy once pointed out that my rear number plate was bent (they dont fit on s13s), then said "oh well, guess theres nothing you can do about it" and ignored it.
no they arent :)
yes they are!
Just because DOTARS says its OK doesn't mean your not gonna get defected.
This has been explained in numerous threads, Dept Transports rules are not the same as Police rules.
And it doesn't matter how many people at Dept of Transport or where ever say its OK, if Mr Policeman says hes gonna defect you for it, he will, because he's the man with the defect tickets.
Still the ADR rule says visible at 45 degrees from 20 meters.
Yep and that is what I quote and I have a bent plate...
Plus this is what the police use as a test, and have seen it done personally...and I have never been booked, and have had the "boys" look it over... :rofl:
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
