George,
It's same as four door and you must have a squillion over there.
What's happening with our little deal?
Cheers, D
The four doors are too damn rare here. Compared to r32s anyway. I'll have a look in the directory for car wreckers surely somewhere up north will have something.
I'll get the Dizzy sent next week :-) Its at course and at the moment its locked up because of midyear recess. Do you need a cap with it aswell? (You know theres no where in NZ where you can buy a new distributor cap for a L20et, but I got a brand new one in a Nissan box off trademe for $25NZD).
Just a good dizzy will be fine thank you George.
I have a brand new Echlin cap here I bought on ebay for AU$20.00 and my stock one is still ok.
I want it for a spare as sure as hell, sometime in the future, 20 or 30 years from now, I might need one.
Thanks,
Dennis
  • 3 months later...
Just wondering if you still have the front seats and whether you could post a photo of them.
I am trying to get a matching pair of front seats for my DR30 and I think the seats in the HR30 coupe are the same or similar.
cheers
cheers
A month or so too late. :ermm:
  • 3 weeks later...
  • 11 years later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
