I don't think there is a section dedicated specifically to engines directly, unless I'm blind so I thought I might as well ask here. Regarding stroker kits that are available for the RB26, which obviously increase the stroke / torque of the RB26 to 2.8L.
My question is why not just bore out the RB26 to an RB28, instead of increasing stroke, reducing the maximum rpm an rb26 can rev to. Increasing stroke is nice, as it obviously adds to the amount of torque that can be generated, but are there any actual big bore kits available?
On a side note, how high can a RB30/26 hybrid rev to? Assuming the engine has countless dollars into it.
Edited by ynhrgt
https://www.sau.com.au/forums/topic/119275-rpm-limit/
From my (limited) understanding boring the rb26 block is not the best option, because there is not a huge amount to be gained before block integrity is compromised. I've never heard of a big bore kit before, but ya never know. Try the search function.
If you have countless dollars anything is possible.
https://www.sau.com.au/forums/topic/119275-rpm-limit/#findComment-2197782
you cant bore far enough to get 2.8 with a standard stroke. well not without eating into the water galleries and reducing strength.
a 2.8 stroker kit is considered to be a nice compromise, more torque, but still plenty of rev capability.
https://www.sau.com.au/forums/topic/119275-rpm-limit/#findComment-2197806
Just use an RB30 block and crank. There was another thread about this, it is a very common conversion with VL commodores to use the RB30 bottom end with RB26 top end.
The RB30 bottom end will be way cheaper than a 2.8 stroker kit, and you get 3.0L instead of 2.8L.
As stated, there is not enough metal on the bores to allow you to bore a 2.6 to 2.8.
In regards to the rev limit, if the engine has been built correctly (i.e. good rods & pistons, balanced, intake etc), then you could get them to rev to 8000 or 9000rpm+ easily. The sky is the limit.
Put it this way, the Trick & Mansweto Capri drag car makes 1000rwhp, naturally aspirated at 9000rpm from a 600ci big block V8. You can get any engine to rev high if you have a good engine builder and plenty of money
Edited by Quinny
https://www.sau.com.au/forums/topic/119275-rpm-limit/#findComment-2197851
I think with std harmonic balancer...around 7-7500 is about the safe limit...what im curious to know is how far could the rb30/25/26 hybrid rev to with an aftermarket balancer like the ati or ross ones? 8,9,10....?
Sorry in advanced if ive hijacked the thread.
https://www.sau.com.au/forums/topic/119275-rpm-limit/#findComment-2198140
with a bigger discplacement (rb30det style) you shouldnt need to rev to 9 grand. its peak power will probably drop off past 6 grand. i think most econo style rb30det's can rev to 7 at the most. thats enough anyway, why rev past that? it wont make more power
the lower the rev limit the better i say
https://www.sau.com.au/forums/topic/119275-rpm-limit/#findComment-2198410
what i was thinking....there is no point in reving the rb30hybrid higher cause its power is lower down...the 2.7 stroker would rev better then a 2.8 too. but a 2.8 would technically have more torque. If you want it to rev stay with a smaller stroke...maybe even just stroke it a touch and put in 40thou oversize pistons etc.
https://www.sau.com.au/forums/topic/119275-rpm-limit/#findComment-2198735
sorry r31Nismoid i meant safe limit for rb30 hybrid...not straight out rb26.
paulr33
But do you know for sure that the power will drop off that dramatically? If you have a head with some fairly wild cams in it, port and polished, solid lifters and the right sized turbo say 35/40 with .82/1.06 rear that power will not be made in excess after 6 grand. Im curious to know, cause the 25/30 were building will be limited to 7k, however if extra rpm can be used it means you can hang onto a gear longer so long as the power is still climbing, fair enough if it isnt then no need to rev it past that point.
My understanding is that stroking increases torque, whilst oversize boring increase the engines revviness. Weve stroked it by using the 3 litre block, but weve increased bore by oversizing it. weve gone both ways, so i would think its possible to get some extra rpm outta the engine, so long as the harmonics are addressed and its gonna make power past that 6k point.
https://www.sau.com.au/forums/topic/119275-rpm-limit/#findComment-2199151
right that makes sense, but why rev much higher?
more rpm means more stress, more heat, more friction and power loss
if you have two engines
one rev to 7000rpm
one rev to 9000rpm
the one that revs to 7000 would likely have less fatigue and stress on it, at least it would seem that way, and also depending on gear ratios, could have a better average power.
https://www.sau.com.au/forums/topic/119275-rpm-limit/#findComment-2199224
Yep, i understand the reliability side, the lower the revs the less strain on everything. But if it comes to the crunch and were really desperate i know my we will want the extra 1k or so to help stretch out the gears, so long as its feasable.
https://www.sau.com.au/forums/topic/119275-rpm-limit/#findComment-2199576
From NISSAN engineer... each parts have diffrent rev for RB26 because that problem is for the cost. The crankshaft rev is about 7,800 rpm. Standard harmonic Balancer is same. The standard valve spring is about 8,300 rpm. But the valve guide is not strong enough for such rev. If you make the best clearance for the valve guide, that engine is no problem 8,300 rpm. When NISSAN raced with RB26 that the short distance race was 8,300 rpm rev (It was sometimes 8,800 rpm rev thouht). The Long distance race was 7,500 rpm rev.
https://www.sau.com.au/forums/topic/119275-rpm-limit/#findComment-2207719
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
