I posted some pics of my DR30 the day i sold it, didn't get it out much when i had it, so most of my mates in these forums would'nt have seen it like this :P
there are a few snaps of my GTR too :)
http://www.skylinesaustralia.com/forums/in...7entry2198437
How much did you sell your DR30 for?
Let it go for 10k, the guy didn't beat me down once, and is happy as could be, ive been told many times its worth more :( i still regret selling it at all. To be honest i think the DR30 was a better can than my gtr, not as fast or powerfull but its just straight up tough! :D and the GTR has 2530's, PowerFC, 100mm Cooler, injectors, 4" zaust, etc etc quite a responsive and powerfull package, but i miss the DR :)
That photo of the engine bay was not as it was when i sold it, i pulled that motor setup out before selling it. I sold it with a pretty tight FJ, haltech, VG30 and a few other engine perfomance bits. The photo of the engine i posted was how i first built the car, fully restored engine bay etc, ran up just over 500kms in a brand new chris miltons engine, made 200rwkws at 9psi, running the engine in :D I still have that engine in the photo and everything to go with it, im trying to decide what to put it in... if i found another DR shell i would use that :)
But yeh, would have nailed a std GTR with a rolling start :)
Roll on it would have to be close to the GTR wouldn't it?
What power was it making?
And I never got to go for a ride in it. :D
Don't feel so bad i never got to go in it either...I did how ever see it reversing next to me whilst i was doing 60 odd after someone had a whoopsie in it hahahahahaha ;)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
