i dont think i can drive it, i can turn the steering wheel one way but not the other and i coudlnt get it outta the ditch, i had to call my mate who is a tow truck driver at 3am to come get me out.... as far as i can see there is no panel damage, but that is the least of my worries atm. i bent the cat back exhaust
Tough luck Darren
crashes suck big time, did you lose the front bar as well?
there is no panel damage at all, the front bar has a scrape on it nothing major, the front wheels wont turn one way soid say the steering is fingered, and im pretty sure i looped it before i went into the ditch, and hit a concrete storm water pipe, smashed up the kakimoto exhuast underneath, its all bent, i think it took most of the hit, but im hoping the diff and rear axle didnt hit the pipe either, if so that woulda maybe bent the chassis and other expensive stuff.
damn mate thats a killer
if you were in brissy i'd be more than happy to give u a hand, but seeing as ur up there wont be able to
i've got a few bits and pieces from my 33 that u can have...aftermarket front pipe, tail shaft, diff thats blown (can use the housing if urs has cracked)
yeah atm i need a cat back 3" exhuast i mite be able to salvage mine, if i can get the muffler that is crushed cut out of it and a straight pipe welded back in. but anyway il let every1 know what parts i need when i get a proper look i guess.
we bloody chocked :(
2-0 to the brazillians
kewell missed an open goal opportunity, breciano missed a sitter, kewel another sitter aarrgghh we shoulda won! :)
now to get another 2hrs sleep before work :D
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
