its ok, i got every channell. and sometimes there is really nothing on..
hahaha, my borther had to pay 72 bucks today to get a fuel line fixed in his commodore.. he put a screw through it trying to secure his subwoofer in the boot ahahah
oh hardcore.
ha ha ha. must have been a million to 1 shot of hitting it though.
wat the sunny coast post was removed :whistling:....
anyone know a website that sells r34 manual gearobxes?/ and will the 6spd gtr fit into the gtt?
i though it was a good idea about the sunny coast thread, at least if we wanted to get in contact with sum1 who lives up here, it was easier for them to find it, rather than having to read back through pages of whore town to maybe find one post.
and about the website, i dont actually know of any, but i know the gtrs have a 6 speed getrag gearbox in them. not sure if they would botl up though, might have to midify sumthing asnd would most likely be costly to buy and modify one.
As for the sunny coast chat, i totally agree., the whole concept of people living an hour from most of ushaving there own section mader sence to me..
it was a nice sub directory inside the QLD section...
when was it removed?
the other day i think. what happened was, sum1 started a section for widebay ppl and they made 2 thread in 2 different sections for this and erin shut it down, then i think sam (baysidebluer34) said sumthing about it being shut down, and he hoped that wouldnt happen to the sunnycoast section, then erin went and shut it down aswell.....
i dont know the full story but thats how it looked to me.
hmmm.. maybe she thought if she doesnt shut it down, then it would look unfair or something....
but i did see a post saying to use ther whoretown... but hell, i dribble $h1T into here and i wouldnt do it if sunny coast were using it..
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
