Anyone got any pics of an engine bay painted in midnight purple or purple pearl?
Sooo cut, was going to take next week off to paint the engine bay (jet black with purple pearl) but the fella im doing this work for needs me for the next 2 weeks arghhhhhhh!!!!
Yeah for job interviews...
Im off for a few hours to go to a job interview to see if i cannot get more money than im earing now. I think its gonna be hard to get more money to be honest. Im slightlly over paid.... :devil:
where is everyone latley , it used to be this was the most whored whore town in Aust (mainly due to old schoolers like Ska & Chaos...) is there a fight club ? maybe I should have renewed my membership even tho I live in NT now (P.S Darwin Blows)
Well in short Ska has to work at work these days and has a busy family life outside work. Plus he is too busy in the stagea section of the forums.
Chaos does not post much at all anymore due to a disagrement and charley and other postwhores dont come round these parts much due to a "newschool/oldschool" arguement which would make a hooker blush.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
