that would be the one yes...i think i mentioned it when u first posted about ur little incident, but anyhoo. let me know when u want to come grab it, im home all week
well i might have to come down on the weekend or something..... unless i get one throughout the week sometime, is your damaged in anyway, why did u take it off your car??
what does a skyline feel like to drive again, i drove mine about 20 metres for the first time in 8weeks today. but it still needs some repairs before it will be fully functional agasin, cant wait aye, i am having withdrawls after driving paro's magna around (makes u wanna drive sensibly bcoz it feels slow and doesnt handle) lol and falcon work ute, goes a bit better but still a p.o.s.....
hmm i see i was the 3rd last post on the the stickers thing... but they aint what im after.. i might have to get custom ones made... am i allowed to make stickings using the SAU trademark stuff?
its in perfect nick. when i bought the second hand diff, the person who i bought it off couldnt be bothered taking it off the diff, so it came with it lol (thanks to martin AKA dragme)
yeah, im pretty confident that in the coming times he'll become quite competative, all he needs is to do is get all that power down and he'll be running some very quick times!
gotta admit, his set-up is quite impressive...i recall his comment on the ignition dvd, that he's seeking sponsorship to aid him going comptetatively racing :(
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
