Actually Mt Cotton day! Woo!
They had a few spare spots so Im going.
Who is running it Dave?? And who is the hiring party?? I don't want to ruin it for someone else, but if they do what we normally do, then that is discrimination!!
Full carbon fibre though dave. Apparantly the Ergo are for the fuller bodied people.
Thought thats what u were talking about. I myself have been playing it for over 2 yrs. What name do u go under? and r u any good?
SDT... Perks of the job (also get my skills up to do the job better) :D Its the advanced course, with normal person cars.
But yeah, what SAU were doing was just hiring the skidpan and lmva, which is different to an advanced defencive driving course, which would have been in keeping with the 'spirit' of mt cotton as they see it. Trust me Im not having a go, I think Mt Cotton have done the dirty with SDT etc and kicking people off the skidpan. But it might be away around it for some of us. I still think they will kick anyone off who is making a lot of noise and holding the slide throughout the whole pan. Just the guy might not be there if we arent listed as a car club...
Either way I think most of us now would get more out of the Morgan Park training.
settle down mark.....
hey bitches!!!!!! a Greatr day to go to the beach!!!
but see as i cant drive and all off to south bank with me for a swim,
see if i can convice a couple of buddy's to go jet skiing...
man lucky i didn't order those plates yet.
man i wanted the FAT801 combination but some other Lard ass has it :D
No pics yet till i actually buy this one!
its a fully stock GTR. only problem i found with it so far is the clutch but that can be easily fixed :D
i hope u've got ALOT of coin to throw at it if ur going to get a stocko john :(
there is plenty being put behind it.
turbo's and exhaust are just the few 2 mods that will be done.
that`ll be a extra close to hundred horses before boostin it hopefully.
what about them big end bearings, u know how much gtr's love to spin them :(
has it had a compression test and leakdown test done on it?
yeah, the gtr has been all tested and tuned.
this is only 1 of the 3 that im testin out. get a choice of which one i want.
compared to the gtst i got right now.... the gtr has nothin compared to the gsts
lol.
that`ll soon change though.
Sorry Lee, I'm off to work!! I know it is rare, but I do work every second weekend to get all those other days off!!
PREACH! I been here since midnight :laugh: only 1 hour and 41 minutes to go... not that im counting or anything >_<
Edited by benigno
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
