slide highflow, no idea on how long but probably not that much long... they said they had to 'modify' the wastegate actuator (ie bend it) so it would shut the wastegate fully, maybe thats still a problem, is it really that bad?
It isnt thaaaat bad (Well it kinda is)
My turbo was heaps laggy for a little while then it loosened up and came much better
yeah i'm doing that now,
driving it it actually sits on 8psi for some reason before continuing onto full boost, doesnt swing right round like it should?
What boost controller are you using? they can help lag to a degree
In any case you need injectors before you can do anything as they are out of flow at about 200rwkw...not mercury 200rwkw real 200rwkw :laugh:
its funny you say that andy as the more i drove it tonight the better it seemed to be, the turbo did sit for a couple of weeks before it got installed so maybe that was something to consider too?
i just thought that they are supposed to make full boost before 4000rpm.
and yeah yeah, the sheet still says 200 something so im happy :) althought the injectors are out of puff :laugh:
i used to have a turbotech one but they said it wasnt holding boost (although was working fine when i drove the car over to them?) but i got them to show me the dyno data which proved it, so now it has a simple gfb bleed valve conrolling boost.
They also had problems with the wastegate actuator (the one on the highflow was stuffed) so they swapped over my old one but had to bend it to make the wastgate function properly? wierd... hmmm
shane do you have msn?
certianly do [email protected]
having a dodgey ass bleed valve controlling boost and expecting it to be 'good' i should come over there and slap u myself :) get a real boost controller i.e Blitz ID3
Yeah when I put mine on it didnt get full boost till 4700 it had been sitting a year...now it can do 1.3 bar by 3300
ur budget is probably alot more than mine, real world example would be comparing nasa space program with indias space program :laugh: (yes i am india!)
having a dodgey ass bleed valve controlling boost and expecting it to be 'good' i should come over there and slap u myself :laugh: get a real boost controller i.e Blitz ID3
Most cases I have seen show the turbotech holding boost pretty well, what more do you want?? Oh wait the pretty screen :) Seriously for medium boost levels a bleed shouldnt be causing too many problems
shane is right, you cant expect to get decent or consistent boost out of a dodgy bleed valve, even cheaper electronic boost controllers will do a much much better job. Go to www.nengun.com and find yourslef a new one asap!
pffft as if, y do u think i do everything myself? if i paid a worshop to do all my work i wouldnt be ablke to afford to do what im doing
Most cases I have seen show the turbotech holding boost pretty well, what more do you want?? Oh wait the pretty screen :laugh: Seriously for medium boost levels a bleed shouldnt be causing too many problems
well alot of people use them no problem, i'm only running 13psi it should be able to handle that
says the man with an avcr :laugh:
now bed bye :)
later :)
i've seen cases of a screw in a piece of vaccum hose hold boost o.k on higher hp cars but still....an ebc can do more than give you a pretty screen, not to mention safety side of things. I remember when i was driving my car one day my ebc came up with a warning and wouldnt let me boost over .7bar because a vaccum hose had come lose and if i hadn't had an ebc I wouldnt have had that function. It could have saved me running unlimited boost and a lot of money.
yea it should but ebc's arent that expensive and if anything at least you have piece of mind, plus you can change and monitor boost levels from the cabin.
no but cost of parts alone i would say would easily be double my whole cars budget?
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
