hahaha @ hiding
And yes, open a new tab, type in about:config
Filter down to ui.key and change the values for these keys around:
ui.key.chromeAccess = 5
ui.key.contentAccess = 4
That should sort you out.
Yeah, damn bogan that she is. At least rain means she won't need the dirt turbo.
me bogan...you taught me everything I know about being a bogan :huh:
Or have you done something Karen doesn't know about.......
Probably...
Hi Jaime :rofl:
*innocent*
BUZZZZZ...wrong :)
hmm I have to find stuff I want that isn't car related.... just can't think of anything help or I will be dragged through the shops.... :rofl: I hate shopping for anything otehr than car stuff
awww its okay karen, im sure someone out there somewhere loves you, even if it is an alien from another planet/galaxy :rofl:
Let me know when you find that person/being...
*runs... very, very far away*
AHHHHH Marc! legend!!
if u werent tied down, i'd so buy you a blow up doll for x-mas
LMAO...
not your day eh karen?
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
