sadly i dont work in those sort of labs - i do blood tests and stuff :) not much fun flammable things in our labs unfortunatley..
there are still fun things to do, but i will prob get in a lot of trouble for mentioning them on this site, also could be classed as terrorism :P
hehehe.....im up for a carwash if u want
but..its raining! whats the point?
my xmas was on nice and quite.....i got a nice new watch
ohh what sort? the watch i want is one based on the mclaren mercedes slr or the james bond ones by tag heuer but they're like 3K too expensive :P
cant say i've dabbled too much in that...we used to mix salt peter (KNO3 -potassium nitrite) with sugar to make reallly good smoke bombs, including one that made a 20m high mushroom cloud and melted a 1ft hole in concerete lol...
our ultimate aim was the manhattan project - a 100kg mother of all smokebombs, but we ran out of funds halfway through so endded up splitting it up into smaller ones :)
lol i didnt even look outside.
na my watch was only 600 guess im too cheap to spend 3k on a watch
Hey guys, seeing as how it is raining and I can't play golf or tennis (except on the Wii)
I and some mates are going to the Pavillion at West End to have lunch and play pool. Around 12.30
Dave
our ultimate aim was the manhattan project - a 100kg mother of all smokebombs, but we ran out of funds halfway through so endded up splitting it up into smaller ones :D
not bad. i cant really say some of my favourite accomplishments, but they are big :) i'll leave it at this and say that we managed to burn a brick wall with a coke can and dent a tree with a d cell battery :P
Morning.
not for much longer
Dave
Hmm not far from work... if they do lunch there I might be able to convince one or two of the very few people working here this week to come along :P
Dave
meh to drivin all the way into the shitty (city) :P
on other topics dave do you have one of those wii's ? how are they? been thinking of getting one but wasn't sure how the controller would feel in real life.
lol, how much did u spend on a watch
i think at least $601 is a good amount :P
haha j/k.. you can get decent watches for even around $150 so a $600 one should be pretty good.
One i have at the moment is 5 years old and i paid $210 for it, saw it in the shops the other day- exactly the same model nothing changed for $250 go figure lol.
i'm in the market for a new one tho, will probably ebay up to $500 or so for something decent.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
