im so so so bored
So im woking and my access to my admin tools is not working, im the only one here and I cant fix it on my own because I dont have that sort of domain level access...
Its really great, all day all ive done is just write shit down in this god-aweful txt doccument that the person who comes in after me is going to have to sort through tonight.
Wheeeee!
booreedd...
mike would i get a discount if i rented a hilux for 1/2 day of thrashing :D
lol for you, maybe. as long as i got to come along of course. for you i could do it for $50 for a full day 24hrs :)
damn you Marc, im in retail, and we've all heard about the stupid stocktake boxing day sales......man im aching!
Well I guess it sucks to be you then :laugh: But yeah, the shops were absolutely MENTAL yesterday, lucky we had the Cressida or we would have been circling for hours trying to find a decent spot to park lol
In need of some sci-fi to put me asleep
Get Ian to tell you a story... *hides*
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
