you see, you must understand young ian, that the world revolves around "pants". without the "pants" you are nothing, and cannot participate in the "great circle of pants" just like in the lion king (but with out elton john) if it has no pants, then it does not exist. there is no meaning to life without "pants".
for when your pants die, and you throw them away. a homeless man finds them, and continues to use them until he gets collected with the trash that he sleeps in. thus dying under the overwhelming smell of garbage and soiled nappies. the pants go with him into the ground, and eventually a "bum tree" is born in its place. from this tree sprout more bums, each with a little bit of those pants, used as a loin cloth.
and so it is that the pants continue this cycle until there is no more to make loin cloths. then the bums discard the loin cloths and mug someone, steeling his pants and the cycle continues.
do you understand now young ian?
sounds as clear as mud Michael :)
glad to see i've enlightened some people with words of wisdom.
although somehow i feel we have all become stupider just from reading it
He saez he was driving quite normally and cut the corner a bit, hit the gravel and ended up against the tree, no real damage except for a dented guard and it bust into flames, he is insured tho.
OH boy Charmed is back on woohoo!
i like that "HE SAYS" lol ouch to him i guess, trying to get his money out of the insurance company.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
