yeah cos John passed out on the couch last night, Shane didn't get any!!!
hehehe :P
Maybe he got some BECAUSE John passed out on the couch... :P
I bet his butt looks like one of those Top Deck chocolates right now... a thin layer of milky white covering a slab of brown
no it'd be more like white malteser's. Milk chocolate outside crunchy white stuff inside :P
Edited by lilmike86
:D
SO WRONG!! YET SO SO FUNNY!!!!
:P:(
i'd like it if he would just follow through for once :P
only if you Swallow :(
or even Gargel like thoose chicks on the Bang Bros movies!!!
fark me some of the girls those guys get to do are so farken hot :P
only if you Swallow :P
lol. i've heard that as a joke before.
Q. Whats the difference between toothpaste and cum?
A. You cant gargle toothpaste,
and marc is right, they would be dirtier than a public toilet at the ekka
Mike now dont tell me you haven't slept with women that have fallen into this catogory :P
yeah, i know a few. i saw one gargle a whole mouthful once, that was pretty cool. then again it was toothpaste :P
i wouldnt touch them with my 10ft pole...... heh.
Depends how desperate i was, and how drunk i was, and how dark it was, and how much dettol they used.
Edited by Oblivion
Depends how desprite i was, and how drunk i was, and how dark it was, and how much dettol they used.
dettol on your pole :P would that burn?? :P
Lubes better trust me :(
he he he
:P
gheyest comment of 2007
Quick, come and stand over near that comment so it looks comparitively less ghey!!
But meh, sif not wanting to go near a skank is ghey. They're a disease lottery, and would be like banging a bowl of mince.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
