lol sux 2 be u i guess. but why would you wait? i'd just say no then walk out mid speach
well i was seriously looking and i was going to ask prices but this guy, he asked me what size i wanted, i said 18s, and he goes nah 18s would look bad, u need 19, or 20s
HMm so whose going on mountain run
18's would be fine, 19's or bigger would be overkill.
i'm going tonight
POWER FC, or if ur keen to cut up ur loom go for an Autronic
LOL haltech's suck major wang, just ask dave :)
as Dave from NSW would call them, autistic. It's f*kn great thought... except for that one time it just died for no reason and we had to drive over 80kms at 20kph because he couldn't accelerate anymore :S But apart from that one time, he seems to be a big fan!
reset your ecu. unplug the battery and leave it for a bit. should reset itself. try it then
edit: also check your wires on the ecu and AFM's could have come off or something
Edited by lilmike86
Off home see you guys tonight!!!
Good luck Ian hope you get it fixeed!!!
stop bloody posting and get stuck into it!!!
bye bye mr lee :) will see you tonight. you better be wearing that dress there!
:mad:
or drive past the beat, or wickham u know why :laugh:
wrong end of town buddy :mad: I didn't mind the wickham. Had never been there til the pub crawl, but I thought it was fine :)
oh poor anna......literally *points and laughs at the poor one*
mmmmmm........hot girl just came into my office :)
yeh :) *sigh* I'll be in the val in about 20 minutes time. Having dinner with a mate from gladstone. But no drinking or dancing for me :)
wrong end of town buddy :mad: I didn't mind the wickham. Had never been there til the pub crawl, but I thought it was fine ;)
you wouldnt have any problems coz they like boys. wait, you might have :laugh:
gladstone huh, i used to live there. hated the town personally. no dancing :) well have fun :)
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
