ha ha ha but i have poo brown eyes >_<
i can't avoid it!!!!!!!!!!!!
oh, i see now (no pun intended) well, just guage out your eyes, problem solved :P
Just be careful of the other guy's poo on them
nah, lee emptied himself out before hand, and i mean emptied. a hose up there will really do that to you though
ARGH!!!
BASEMENT f**kING JAXX :P>_<
*stab stab stab*
Just take me back to your house!!
your house!
I dont want to go home all alone!
Just Take me back to your house.....
:D dam friggin catchy song.....
4 words:
SOMETHING YOUR NOT GETTING!
:P
Nah you have it all wrong. Shane gets heaps of sex, apparently there are plenty of guys in his area willing to put out... or at least take their teeth out for him
hahah is that so mike >_<
the lightest of lightest wheels (without going magnesium or titanium of course lol)
titanium ftw, thats what i'm after anyway. *looks at price tag and starts to cry*
and marc......*shudders*.........but doesnt he have to pay them? i mean its shane, come on :P
is it that take you back to my house or whatever song?
Indeed
I can't stand it!
lolz
hmmm what about these...
>_<:P
nah titanium isnt cheap is it, when i ordered my rods, i priced the titanium ones, and for a set of 6 they were gonna be US$8250 compared to US$1100 for billet ones :P
:woot::yes:;)
Have you seen the copies of the Rays Volk's?? RAVS VORK's >_<:D
ur joking right? ;)
whats the quality like? :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
