hahahah they're only human right?!?! :yes:
Everything seemed to have gone quiet after Annas myspace photo was brought out .. I think they initiated this 'rubbing out' you speak of ;) *giggles*
BAHAHAHAHA
Said act should result in them dying in a fire.... :stupid:
:wavey:
herro yew!
Congrats missy!
*hides mega anna-induced boner*
I mean *ahem*
hi!
ANNA!!! :stupid: come for a drink tonight to celerbrate sweetie!!
Awwww, I would love to, but the car is undriveable, the clutch is being put back in tonight!
that is true.....
she is my favourite ever...
ANNA! This is Nikita I was tellin ya bout :D
who shares the hate for certain peoples :stupid:
hahahaha I can only imagine everything Anna (LIL34) told you was alllll good :yes: .. And probably how much she wants to be like me!
hahaha
Nice to meet you anna (the non LIL34 one!)
:P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
