yea saw the business thing is sorta taking off ay.....do you do that full time now? Pics of onevia?
havnt taken any in about 2 months since i got it
bought it with no motor and box
put the rb20 in it
threw on a highflow
tein coilovers
vertex kit and super advans the same that are on the skyline
Just need to paint it and throw the stickers on it and shes good to go after a minor electrical problem is sorted
better give them a minute to take their arthritis meds first, dont want them putting a hip out :glare:
Don't hate that we are wiser, cooler and 1337er. Hate yourself because your a n00b, whose opinions dont count. One day people might stop and listen to what you have to say, possibly even come to something you organise or more importantly you might be invited to attend something private.....but that time n00b is long away, until then sit, listen and observe and maybe some day soon you'll find acceptance.
put the rb20 in it
threw on a highflow
tein coilovers
whose doing the work for you??
ok mr parts fag. Im sick of yahoo jp kids not able to help me.
I want a boss kit for a nadi wheel for a 1991 UCF10/UCF11 Lexus/celsior.
No cruise controll as i took it off, JZA80 is meant to fit.
No go find out, and will order.
Ill get back to you barry
:wave: what happed to your location??
your were striaght outta compton yesterday Hommie :glare:
was up mine nigga?
What?? It should still be straight outta compton yo! .. But I never had that in as my location cracki!
How you today turd nugget?
sorry, what now?
:glare:
don't start a war you can't win...I will win the post changing war...ask some of the other n00bs like in teh sunshine coast thread! Sometimes your actual post gets changed (dont know by who) and then you look like a real moron, because it stays like that forever, and then we make whole threads about it and pwn you constantly...well you know just speaking from the past...something you would know nothing about...
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
