Its probably a meeting to decide if they are gunna have a meeting to decided if they have a conference.
your close...its only the pre-meeting though. The step before the ones mentioned above...it follows 2 years of serious "talks". I think its in regard to North Korea...which means by the time they take over the world..we might be ready to do something.
:ninja:
Hi
THERE IS MY EVIDENCE ANDY!!! pwned, and in a straight line!!!! and then you expect a skyline to be quicker round a corner!!!
i rest my case
Who said I was saying my car is faster
Holding a hammer doesnt make you a carpenter
i rest my case
i think it was also evidenced the guy probably couldnt drive...it was standard and based on the power to weight ration the skyline should have won. He probably launched it at like 6k and spun the tires for too long, then missed a gear or something. If the Mx5 got off to a good start and him to a crap one not hard for the mx5 to win over a small stretch..lets remember they were on the street.
i rest my case
Ps it was a near stock R33...my nanna pushes a wheel chair faster
that is true, btu the coments further down were more interesting to me :ninja:
power difference of 51kw and only a weight differnece of 200kg, i dont see much advantage to the mx5 really
does your nanna have a motec system exhaust and a stand alone fuel management system??
rofl jackass 2, the wheelchair with nos! ahahaha they launched the guy off a ramp into the lake!
She has a laptop plugged in to her too! Controls the sub woofers and the mapping
Yeah that comment was me saying they are both slow
my biggest point is, you're all willing to bag it out, but when i offer to take it to the circuit, you all avoid the topic. i never said i would win, but i did say i would take anyone on.
i'm willing to try and prove my point, but no one is willing to step up to the challenge it seems. if its so slow, then how come i have no takers?
i rest my case
Hey the MX 5 is about as heavy as the silvia and i have about 200kws so i should be pretty fast right?? in a straight line that is, now need to get out on the track and polish up my skillz...
Hi
:ninja::)
mike there are many people that will just wait for the SAU track day then you can see who has the balls and skillz...
um, sorry lee, thats a 1999 model. mines an 89. it'll weigh 800kg and have 250kw by the end of march (hopefully, just needs a tune, which needs money) but please, come to the track lee, that makes one person! any other takers?
At the moment we arent talking about this car you are buying..we are talking about a stock MX5
I will recap so every one understands
You said here is my evidence becuase a stock MX5 beat a slow R33,How does that relate to you in any way?
And I was saying that the comparison to the R33 is bunk because my car is nothing like that car and both in the above comparison were slow
My car weighs 1290kg (Yes I weighed it myself)
My car makes 260wrkw
My car has run a 12.4
Come winter I will more than likley be at the track, see you there
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
