yeah i dont know much about them but i know i need one lol
but i will learn quickly. just gotta buy hand controller now. then il wait till i get further mods to my car before i install them all at once and get it tuned.
power fc are good, i went from 172 to 231 kw at the wheels with a pfc and slide highflow :woot:
oh and daz there's probably gunna be another skyline up your way soon :(:woot:
i be good little mikey, hows the car purchase goin?
i'm flying down there tomorrow to do an inspection. if all goes good i will transfer funds over on monday and it will be sent up here on the back of a truck (free mind you :( )
oh and daz there's probably gunna be another skyline up your way soon :P:woot:
you moving isaac :ninja:
i'm flying down there tomorrow to do an inspection. if all goes good i will transfer funds over on monday and it will be sent up here on the back of a truck (free mind you :woot: )
you moving isaac :(
wow cool, but wont you need queensland transport mod plates and stuff to register it in qld? are they able to approve that?
and maybe, i'm going for a job up that way yes :ninja:
and maybe, i'm going for a job up that way yes :woot:
already had a talk to rotary motorsport and they said for $150 they will mod plate it for qld. i'll keep the SA plates on it till i sort it all out though hopefully :(
ahh k
so are you at work today?
for one more hour, then i'm done till monday :( yay!! :balloonsandshit:
although i gotta get up at 4:30 tomorrow morning to go to the airport :woot:
The SAU forum shares the same server as the ATO super computer and with my Admin status it gets confused...
hmm well can you pls ignore my last tax return as certain things were claimed as maintenance that weren't really maintenance (fuel pump, clutch, brakes, dyno runs) :woot::(:ninja:
I'd prefer the slingshot if they actually launched them over the mountain...
i was hoping they would, or she'd fall out and go through the building. that would be funny :woot:
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
