Depends what boost it does it at..mine does it at 7psi or less, I have the BOV spring pretty tight to avoid leaking at idle and stalling, If it does it at high boost it can be a problem as it strains the shaft with the sudden stopping of the blades.
This car is only running 6psi so it is fine..when you want to run more a BOV would be wise, that said Dave ran no BOVs on his T04Z at 20psi and it is fine, apparently BB turbos are more resistant
ok, thats the answer i was looking for. thats what i was thinking. just wanted to check it, coz the turbo has clicked over to 5000k's now. so when i increase the boost i should install a bov :laugh:
mine died because of it, it just went "nup, f*ck you! too hot!"
ok, i worded that wrong. i know it has an internal wastegate but he has removed the stock bov (dont know why) and left it as that.
no, no pics. phone decided it doesnt like multimedia anymore, stupid nokia
i know the difference, but thats exactly what it was doing. to quote: "the noise your turbo makes as the throttle body closes, and the compressed air is "chopped up" by the blades, and makes that noise"
apparently it really f*cks the turbo up
morning apparently it does. but heard of a dew GTST on the forced inductiong section running no BOV for years.
thats the most Boob action you've had in a while hey Mike :laugh: now you can go back to your corner and do some one handed typing :P
you cant blame me for your deficiencies. just coz yours arent as good you take it out on me? pfft, get a boob job lee
bahahahaha like i said! we all saw boobs on sat night!!!
:laugh:
there are some in this "collection" i don't even remember getting taken BAHAHAHA
it's like a timeline in photo's... they start off normal and nice.. :P
then it all go's downhill
haha sounds like a good nite out :wave:
:laugh:
post them up woman... Downhill Photo's FTW!!!
:laugh:
down hill or down south :wave:
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
