Nothing wrong with a thread thats brings some older members back...
i agree. It wasn't anything worse than the millions of other threads that are opened on here every day of the week....looks to the sunny coast thread amongst others....re-open ftw.
Keep it to whoretown boys...
Everyone has fun from time to time, but all fun has to come to an end when there are complaints...
Im sure you can imagine many sh1t threads are started on a weekly basis, as soon as another one is started people just complain.
"Oh but smoothline has his thread open and its just crap, why was mine closed and his was not"
One set of rules for everyone, im sure you understand. Im all for a bit of fun but it gets to a point where is no longer needed...
"Customer compalints"
Tell Mr TOY33 to jam it up his clack next time... :laugh:
MrTOY33, your a whiny bitch and should be banned for detracting from the QLD forum.
Anyone else who complained, you're in the same boat. I thought all the complaining ended when Erin left? rofl
Edited by SmoothLine
FYI: It was not John...
Most of the threads started that are complained about are because they are using rediculous language and are referencing stupid things on youtube or such. Other than that, its public forum. The crap threads from whingers, quickly die..there are many that we all know about. But if people are posting in the thread, be it fun and talking about things some of the newer members dont understand, why should that be our problem. We cant keep track of each other or what we say in whoretown because theres too much crap posted in here all day everyday by n00bs trying to up their postcount!! I dont understand what they have a problem with? Us having some fun?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
