hey guys does any1 know the difference between the old and new version of the power fc, and how can u tell what is what??
i need to find out what handcontroller will be compatible for my power fc when i get it.
older version hand controller part No is: 415-N001
newer version hand controller part No is: 415-X001
any ideas??
Thought all that gear was discontinued, with apexi going bankrupt and all...
i got mine second hand for the computer, just need to get hand controller now, just dont know what model to buy, as i m not sure if its the newer version of the power fc or older one. i dont know what they consider old or new, R33 = old or new?? or do they have old or new models for the r33 model, im confused.....
i think paulr33 has a list of models and there compatible hand controllers on his site.. better yet why don't you pick up an FC datalogit and use your laptop (if you've got one) to tune instead, so much easier
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
