Age is old new. Pipe down, and listen to the future.
You know it's true. I don't hide it.
I smell pretty anna banana.
My tax is more then most people's income.
How sad for the common people.
Thats aboriginal for more bullshit
revert to my original post....go f**kyaself
Maybe your just so upset because your 52, you decided to have a midlife crisis, buy a skyline and become "cool" again to satisfy the need you never had in highschool.....but your realising that the young ppl don't like you now either...and you're realising how much you really do hate your life? It almost makes me feel sorry for you.
let me guess, this is aborigional for bullshit? Aborigionals really need to learn more words, although I almost admire their simplistic ways of making short conversations.
Obviously being a spoilt brat doesnt increase ones capacity to respond with a witty retort.
Why bother with wit?
My life is alreayd better then yours. Come say high to me at the dyno day, I have the Lexus in primer, i wont be mean to you honest.
Maybe your just so upset because your 52, you decided to have a midlife crisis, buy a skyline and become "cool" again to satisfy the need you never had in highschool.....but your realising that the young ppl don't like you now either...and now your realising how much you really do hate your life? It almost makes me feel sorry for you.
No, quite wrong in fact. For my midlife crisis I bought a used bart simpson figurine. cool again is also wrong. I have always been cool. Wether you like me or not is totally irelevant. I doubt that I will toss and turn worrying about it tonite. And, trust me puppy, I love my life. :(
p.s. wtf is high school?
you know the funny thing, matt and josh dont own skylines, they own TOYOTA's :(
P.S 6 bolt main, niggah please
I've owned more nissans than you i'd say, and all probably had more power than yours as well...so go back to your hole.
Why? cant afford to paint it? do you park it beside the caravan :(
Lets see now
180b
200b
swb patrol
swb patrol
long wheel base patrol
skyline
skyline
lwb patrol
lwb patrol
maxima
lwb patrol (current)
maxima (current)
skyline
and your list is?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
