COULD THIS BE "THE EVENT, 2007"????? I wouldnt mind organising one and we could just all own a test n tune one wednesday (the slower of the two days) or if we got enough ppl, hire the track for a period of time.
mid 11's
1.8 60' with 265x17x40 hankook k104 with a R33 gtst and 191rwkw :thumbsup:
I reckon mid 11's as it sits in the garage atm with street tyres...
I think high 10's are possible with slicks...
As for the 60 foot time, I have a slip framed on the wall when i beat Dave...
I ran a 1.67 60' woth 255x17x40 (yum-cha's) with R33 gtst and 198rwkw :teehee:
im in..
COL as super mod.. can u make this an organised event..
SAU drag day in winter on a wednesday night..? :teehee:
should be fun.. i wanna race old man noel. :thumbsup:
im getting at u should build the motor so u can run that 24psi :teehee:
Yeah yeah... Ill build an rb30/26 one day when i get bored...
Then again buy then someone might steal your car and I can buy your motor on the blackmarket cheap cheap... :thumbsup:
well if my thing dont run mid-low 10's i'm gonne roll it off a cliff :thumbsup:
did i mention my run was with hard as fark teins? lol
im in..
lol mark, anyone can organise an event....it's not easy though, especially if you want to hire out the track.
im in..
If you want it to be official then you would have to speak to one of the clubs events execs not me...
Im a moderator for the forum not and exec of the club...
As for the tnt's the club cant afford track hire so we just tag along to these tnt nights...
not a bad 60' what was teh et?
13.5 @ 107, was a very granny like shift into 3rd, as the run b4 i missed it 3 times :teehee:
Then again buy then someone might steal your car and I can buy your motor on the blackmarket cheap cheap... :blink:
26/30, i like the way u think :laugh::thumbsup:
hence why im keeping it stock as possibly on the outside, so it dont get noticed
we could afford track hire if we got enough ppl together and got them paid, im not talking about hiring it for the day but a few hours. I've been to a few private days where workshops have hired it for testing prior to jambo etc...trouble is obviously getting the people and getting them to pay.
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
