:D farking not cool Mark goes give your car a bit it said what here up this hill? he say yeah so i put it in 3rd and boosted just a little... stopped right behind a barina with the cops to me left :laugh: farking silly... then i launched da barsterd rght infrom of the cops shop alittle to give mark an indication, and if he could tell by my gear change it has been a while since i've launched and flogged the car...
maybe u should give it to an independant observer, like myself, so i can give unbiased opions of both cars
:D
its u....so what was the verdict mark, lee, is the swap on?
i doubt it, mark's being a picky little b!tch and lee's offering too much :laugh:
i.e in reality the gtr is only worth 19k max, and lee's sil has had a fair bit of work done recently! new turbo, tune etc etc plus lee the tool is throwing in a pair of recaro's!!!! seriously lee's stoopid lol
but hey, that's just my opinion :D
interesting but still....a silvia is a silvia no matter how quick or clean it is....josh sold his 10 second one for a hell of a lot less than what you'd think (I wont mention in case he doesn't want me too). Nicely modified newer 33's and the like are selling for like 13 and 14k these days so i guess you have to put it in perspective...imports in general just aren't worth anything anymore. But yea...
:laugh: farking not cool Mark goes "give your car a bit"
i said :what here up this hill?"
he say "yeah"
:D farking silly... then i launched da barsterd rght infront of the cops shop alittle to give mark an indication, and if he could tell by my gear change it has been a while since i've launched and flogged the car...
im actually quite suprised with how it went.. very interested.. also ur driving aint bad lee.. :D
im happy with the deal shane.. and im sure lee is happy with my GTR.. its clean aye shane.. i knw what u wer thinking when u saw it. and einstein liked my exhaust.. :D and think i suprised u all with how quiet my nismo exhaust is...
anyway.. i better sleep sau.. night thanks for the great night..
GRJ120R Prado gets OWNED... somewher on northside..:wub:
took pic months ago only found tonight when cleaning pc up haha..
the driver tried to park at the guide dog place off the street and slipped and got stuck in that weird position.. soo much for DAT downhill assent technology..
:happy:
Edited by markimak
well stop farking talking about it and actually show up! either that or stfu matt, seriously dude u guys talk about how its not good nymore, maybe start rocking up and actually witness it first hand, rather than making up crap.
I live in farken Noosa, by the time I got home from dinner, it would be time to get up agian for work.
I call the fark that flag.
only if you dim the lights and we can cuddel afterwards....
oh and good morning ladies...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
