Hope you've made the right choice for yourself anyway Josh, better than court IMO :P
Anyways I'm off...baibai all :happy:
It's a much better choice, however it is a HUGE effort now to get my license back.
I do weird things, I just didn't want to give the Police the joy and satisfaction of beating me.
lol, what did you get cuaght for??
What time? lol.
In short, I was appealing a suspension, and they were opposing it with 4 years of evidence as to why Im no longer fit to hold a license.
I ditched the license, they can't oppose shit now.
i had my dad take my car to a tail shafting place today, to get them to see if the tailshaft was out of balance at all, and i told them if it was to fix it. bcoz i thought it was slightly out.
anyway dad dropped my car back off at my work i didnt get to drive it till 5pm on the way home and when driving it home then whole rear end has a terrible shudder now. worse then ever before, so i think they have over balanced it or something, i dont know why they touched it in the first place if it didnt need doing. that is what i told them anyway... i dunno i give up aye....
Just skid it, it will either get better or worse
:ninja:
so they'll probably impose some sort of restriction withholding you from obtaining your license for x amount of time or something...lol sucks ass but at least you beat them to it sorta....
damn that sucks, just live in hope that one day it will all be good lol
yeah so annoying, so now i gotta take it back to them to say for them to fix it.
hope they do. i just want it back the way it was now it wasnt too bad after driving it now lol
its like some1 has welded some steel to the tail shaft and its not spinning correctly now causing it to shudder, problem didnt need fixing in the first place by the looks of it, it could have easily been something else doing it, but i thought they would know if it was the tail shaft or not? since they are in the business.
thats correct, however the national data base wont get updated, im not even listed as a licensed driver, shows just how slack they are, and only keep an eye on their own state systems.
So, yeh I could go and apply and take the test for a vic license, just have to watch out for where i drive in qld
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
