Heres the go Milky.
A. you dont own a skyline
B. you arent a member
C. you are a cockhead
Three strikes and you're out, Onyabike tosspot :):laugh:
bahahahahaha here's the go for you oldtimer:
A. You're old
B. You're a n00b
C. You think you're cool
D. You're a wanker
funny thing about you Oldtimer is, you think paying me out is going to get you rep points, but problem is i've been here a lot longer than you and you've been here 2 minutes and already think you make the rules (1: overall, hardly anyone is a "member" 2:heaps of people don't own skylines on here and 3:Your opinion doesn't count for anything) I've seen you mid life crisis type go through here quite a bit..given your case is a little sader but none the less....like I said go back to playing with your car, putting on the wrong offset wheels and talking about your awesome alarm you got installed by autobarn.
Mightnt be for you but it would suck for me. i doubt that any road rules we tested under are even in existence today. :)
dude back in your day you could get other people go for licence for you and i think the test was to drive the coppa down to the nearest takeaway and buy him lunch.... true story....
Mightnt be for you but it would suck for me. i doubt that any road rules we tested under are even in existence today. :laugh:
This is true, wouldn't be worth it. Nothing has changed enough for me since I 1st got my license to make it hard, where as in 1928 you'd have what like 2 rules? :)
Josh's great trickery scam sounds good on paper, but we're forgetting Vic license = I must drive cars that meet their power to weight.
P.s f**k using a p plate haha
Morning milky. had your heinz 3 veg mix yet. :)
ahahah LOL :laugh:
Feeling tough this morning??....f*ck off and die already...i'm sick of wasting my time arguing with you...you're always wrong, your arguments are crap and you aren't worth my time.
ahahah LOL :)
Heres the go Milky.
Three strikes and you're out, Onyabike tosspot :O:D
ahahah LOL :laugh: + :D
NOELS WINNING MATT... :D
anyway morning sau.. did u all poop alot since last night..? im eating beef meatballs and fried rice :D
if only you knew how true that was bloke. However, after i left the outback and came to Bris I managed to actually lose my license a time or 2 and had to sit real tests. That sucked.
u have to stick up for noel or u'll be walking half the time!
Niz and ole grey one have reached an understanding. He understands that I am a cantankerous old c#$#$
And I understand that he wants to be just like me when he gets old. :):):)
My mum's dad was an inspector in NSW..and what you're saying is right, except that in her case the licensing officer asked "can she drive mate" he said "yeah shes a good driver" She got her license then and there...hahaha
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
