evening you punk bitchaz...
my second last day in brisvagas before flying up to happyrock aka gladstone :)
lol i emailed my list of demands for moving to rocky to our state manager, it included relocation costs, temporary accomodation until i can find a flat to rent, and a serious payrise.... hehe i know the companys desperate so they'll have to cave, otherwise meh i'll go to buderim as i'd prefer to work there anyway :sorcerer:
He is in bed with his brother, another guy and a chick watching harry potter,...
Hayahaha. aww you do listen to me.. I was, but now im in my bed alone :( waiting for shane :P
lend me cash kthx
already offered and you turned it down hahaha :P If you honestly needed a loan I could help you out..(not through me personally) But I know a good company that deals with that sort of thing :(
Holy f**king methuiselah, what the flamin hell is going down in that mag thread. Talk about tits in a tangle.
John's a fag..he's getting whats been coming to him for the past 3-6 months...for all the crap he's talked about everyone and how he's tried to rip everyone off....read it if you can be fcked.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
