Apart from a short stint in Beenleigh, I have hardly seen ANY mumble pants since moving out of Ipsditch. Considering the quality of people wearing them in those areas, it's not a sight I'll be missing any time soon.
I gotta ask, when are you geting and putting on your hiflow turbo noel
Turbo will be ready first week in march adam. will have most of the other shit I need by then too. the great unknown is still the f**king computer. I just cant get a definitive answer. :(
I doubt it's that big of a deal...lets be real...it's sizzlers...as long as you don't rock up looking like a tool I don't think they care....
well he's fired then :( lol not his fault he just happends to naturally look like one...
PFC will do pretty much everything you'll want. It plugs into the factory loom, has a good base map (in that it'll get the car running immediately, the maps won't be anywhere near correct), and there are plenty of people who can tune them now.
Haltech is getting some big fans, they will cost you more but will do everything the PFC will plus proper knock control (as opposed to just detecting it and flashing a warning, but not actually doing anything, like the PFC) and is more expandable.
I used to run a PFC and was more than happy with it, I didn't make insane amounts of power or anything but it had different injectors, AFM, turbo, cooler etc and the PFC ran the lot very well, and it still did 500+km per tank of fuel. They're getting hard to find now though :(
Oh BTW there is a difference between the series 1 and series 2 which means that unless you want to modify your ignition system (S1 had an ignitor box, S2 integrated them into the coils) apparently you need a different ECU. I'm not sure exactly what the difference with the S1/S2 computers is but they're different part numbers in the PFC. Either way it's definitely worth keeping in mind.
See what i mean, theres another partial answer marc. Knock sensor. good to have. Knock control, better to have. What else, dual mapping, timing, spark, air fuel, Just what should a good puda have and be able to do with what it has.
Marc's exatly right...the PFC will EASILY handle your mods and is tunable by some of the best tuners in the country, right now, just down the road. You're not building a 700+hp car so you don't need the extra features a more expensive ecu has to offer. The PFC is run by many cars that have in excess of 500hp with no problems at all, it's an extremely capable ecu and it's one of the most commonly recognised ones amongst the tuning industry. It's hard to go past for your application imo.
Read my last post Matty. i have been around hot cars long enough to know that my mods probably wont stop at that. The puda is an item i only want to buy once.
- Well a PFC gives you full access to the 20x20 ignition timing and fuel correction maps.
- Air flow correction values can be entered for vehicles upgrading air flow meters.
- Injector pulse correction menu is used when upgrading injectors on the engine.
- The Acceleration Enrichment Correction function improves response under hard and sudden acceleration. (similar to what a SAFC does)
- The Cranking Fuel Injection menu corrects the amount of fuel when the engine is being cranked, or when the water temperature is cold.
- A separate Water Temp menu allows fuel correction according to water temperature.
- The RPM menu allows rev limiter settings and idle RPM levels.
- Complete boost control is possible by using the optional Boost Control Kit
It's also very easy to use, which is a big plus as well....
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
