Apart from a short stint in Beenleigh, I have hardly seen ANY mumble pants since moving out of Ipsditch. Considering the quality of people wearing them in those areas, it's not a sight I'll be missing any time soon.
I gotta ask, when are you geting and putting on your hiflow turbo noel
Turbo will be ready first week in march adam. will have most of the other shit I need by then too. the great unknown is still the f**king computer. I just cant get a definitive answer. :(
I doubt it's that big of a deal...lets be real...it's sizzlers...as long as you don't rock up looking like a tool I don't think they care....
well he's fired then :( lol not his fault he just happends to naturally look like one...
PFC will do pretty much everything you'll want. It plugs into the factory loom, has a good base map (in that it'll get the car running immediately, the maps won't be anywhere near correct), and there are plenty of people who can tune them now.
Haltech is getting some big fans, they will cost you more but will do everything the PFC will plus proper knock control (as opposed to just detecting it and flashing a warning, but not actually doing anything, like the PFC) and is more expandable.
I used to run a PFC and was more than happy with it, I didn't make insane amounts of power or anything but it had different injectors, AFM, turbo, cooler etc and the PFC ran the lot very well, and it still did 500+km per tank of fuel. They're getting hard to find now though :(
Oh BTW there is a difference between the series 1 and series 2 which means that unless you want to modify your ignition system (S1 had an ignitor box, S2 integrated them into the coils) apparently you need a different ECU. I'm not sure exactly what the difference with the S1/S2 computers is but they're different part numbers in the PFC. Either way it's definitely worth keeping in mind.
See what i mean, theres another partial answer marc. Knock sensor. good to have. Knock control, better to have. What else, dual mapping, timing, spark, air fuel, Just what should a good puda have and be able to do with what it has.
Marc's exatly right...the PFC will EASILY handle your mods and is tunable by some of the best tuners in the country, right now, just down the road. You're not building a 700+hp car so you don't need the extra features a more expensive ecu has to offer. The PFC is run by many cars that have in excess of 500hp with no problems at all, it's an extremely capable ecu and it's one of the most commonly recognised ones amongst the tuning industry. It's hard to go past for your application imo.
Read my last post Matty. i have been around hot cars long enough to know that my mods probably wont stop at that. The puda is an item i only want to buy once.
- Well a PFC gives you full access to the 20x20 ignition timing and fuel correction maps.
- Air flow correction values can be entered for vehicles upgrading air flow meters.
- Injector pulse correction menu is used when upgrading injectors on the engine.
- The Acceleration Enrichment Correction function improves response under hard and sudden acceleration. (similar to what a SAFC does)
- The Cranking Fuel Injection menu corrects the amount of fuel when the engine is being cranked, or when the water temperature is cold.
- A separate Water Temp menu allows fuel correction according to water temperature.
- The RPM menu allows rev limiter settings and idle RPM levels.
- Complete boost control is possible by using the optional Boost Control Kit
It's also very easy to use, which is a big plus as well....
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
