u've been fed bs then lol
nope... check it again Shane they just revised it..... do a John and ask a random coppa, while you fueling up when your gtr is running again :D
no man i'm for real they have changed it to 15 and are getting everyone...
if they have changed it to 15cm then i am truly screwed... :D
but i dont think they have can you prove it?
If thats true there are even some new cars that wont cut it.
Which one? the loganholme on i guess..... might have to come pay you a vist.. or have SAU TND there lol and i will flick shit at u all night long and you cant do anything about it :D
ahaha yeah lets have tuesday night dinner here..? i cant make it on tuesday anyone.. im working.ahaha i can say that now! if u do come i think ull all get 20% off cause i got a card u can all have.. just for the night. :(
Neat cas bloke. clean comfy shoes as you will be on your feet a bit. you will be around food so dont wear colours that show stains so readily.
had my first... all good hope i get paid for it..
dress up in a rat poison suit???
ahahah GOLD :(
And lots of pockets so you can fill them with jellybeans for us. :)
did that as a kid
I agree...stick with dodgy brands....
i wore tarocash, fila socks, tarocash shoes, and YD. pants.. and Kmart boxers lol..
well mark i'd suggest, slappers, stubbies and a singlet :(
yes shane ill dress just like u my bogan pal
mark, ask ur missus, im sure she'd dress you in something nice :D
and wat does that mean..?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
