Maybe you should cover the woodridge pearl lexus in foil then add a layer of gladwrap for that clearcoat finish look.
I've left it in the street half way up the street for 3 days now, and no one has touched it!
Yet someone broke in, and stole the last porsche.
I cant even give the lexus away haha
well, I hope you manage to get it done in time!!!
as for the hsd, well both Andy and Fatz (from down here) raved about them, but I just went for the tein monoflex, it was a fair bit more but definately heads above the rest IMO.
im not heading down there if i dont have new rotors and suspension. and i definately wont be running the 750hp or so its capable of, i dont wanna die in my first track outing :P
hmmmm, this is ghey, i hate making decisions like these, i mite just bite the bullet and give the hsd's a run :P
What oil control mods do you have?
Why?
JIC, buddy club, endless they are all better.
dave (our dave) wouldn't let me get anything other than tein's for my 150rwkw 180.. so if that's anything to go by, I'd take his advice! I believe he also might be gettnig the same thing when he needs coilovers!
Only down fall with teins is they dont have seperate spring preload.
i heard the valving in the teins isnt all that advanced, and theres plenty out there better. also with the hsd'd u can specify ur own spring rates upon purchase. also hsd's have a 55mm alluminium assembly
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
