Maybe you should cover the woodridge pearl lexus in foil then add a layer of gladwrap for that clearcoat finish look.
I've left it in the street half way up the street for 3 days now, and no one has touched it!
Yet someone broke in, and stole the last porsche.
I cant even give the lexus away haha
well, I hope you manage to get it done in time!!!
as for the hsd, well both Andy and Fatz (from down here) raved about them, but I just went for the tein monoflex, it was a fair bit more but definately heads above the rest IMO.
im not heading down there if i dont have new rotors and suspension. and i definately wont be running the 750hp or so its capable of, i dont wanna die in my first track outing :P
hmmmm, this is ghey, i hate making decisions like these, i mite just bite the bullet and give the hsd's a run :P
What oil control mods do you have?
Why?
JIC, buddy club, endless they are all better.
dave (our dave) wouldn't let me get anything other than tein's for my 150rwkw 180.. so if that's anything to go by, I'd take his advice! I believe he also might be gettnig the same thing when he needs coilovers!
Only down fall with teins is they dont have seperate spring preload.
i heard the valving in the teins isnt all that advanced, and theres plenty out there better. also with the hsd'd u can specify ur own spring rates upon purchase. also hsd's have a 55mm alluminium assembly
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
