If I pay $30 for steak, I like it to taste good...and like I said, theres a reason all the best restraunts in the world cook steaks only rare or medium-rare...or as the Chef likes (which is rare or medium-rare) and you don't get a choice lol.
well all i know is that i wont eat raw meat, to me it looked raw. the waitress even spotted it before i said anything as did the couple in the next table.
Taste is a subjective thing, i cannot stand the taste of raw meat, i rather it is thoroughly cooked. To me that is a good steak. I dont care if i eat in a pub in emerald or a flash restaurant where you're not walking out with change from $100 for a basic meal, well done should mean cooked through the whole way
I,ve been eating those hookworms and parasites for a lot of years with no ill effects. Besides, Charcoal causes cancer. >_<
a steak with lots of charcoal on it is not a good steak either, i like meat cooked but not overcooked.
studies have shown charcoal causes cancer yes, but like anything in health science nothing is certain- the benefits of using charcoal to treat intestinal problems and poisioning cases are well known.
You keep eating charcoal and when you get to my age come dig me up and let me know how you are doing. >_<
Go cook a nice rare steak with onions and shrooms.
well at least the onions and shrooms are on the money :sorcerer:
pity i've no food in the place as i just got home from out of town >_<
pity i've no food in the place as i just got home from out of town :happy:
So why didnt you bring some fresh roadkill home with you. Soft bro, soft. >_<
I have this problem, no food, nothing frozen and the Lexus is up on car stands with no suspension, Can’t even trek it to get take away.
On the upside, I’m cooking pasta, just nothing to put in it. Pasta and cheese perhaps FTW?
We will see.
We will see.
i have used beans as pasta sauce before works quite well...even thought about straining out the beans and just using the sauce cos i hate beans lol.
what about tomato sauce? or even bbq? tartare? mustard? teh metro bush tucker man will forage for whatever food he can find in his environment lol
I have some BBQ, no tomato, have some "American" style hot dog mustard, not a fan though I like seaded. I have corn in the frezer, maybe i'll throw that in too.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
