Just pasing by! I land in Brisbane next week, is anyone from the CBD?
Not that i know of but you may want to join in the tuesday night dinner if you are still around then. We usually have a good time. Welcome to Bris.
Thats the plan but where do i find a lip.
could put a gtr lip on the bottom....other then that design one and get someplace to make it. i dont know who else just does lips.
He doesn't have a gtr front bar so I don't like his chances of attaching a gtr lip. I personally don't like S1 front bars but hey, its all personal preference. If i were you i'd get a Jun or topsecret front bar.
Answer me this puppers. Does anybody make a lip for the standard 33 series 1 bar. f**k all the aftermarket bars. They look like a block of flats and arent worth the trouble I see dudes going to to avoid gutters, speed bumps etc.
u'll find the main factor behind front bar design is airflow!
vents etc aid in directing that airflow
i personally love this bodykit
http://www.do-luck-usa.com/products.html?auto=BCNR33
Seems to me that designing my own is the only way I am going to get what i want. I am after the late 70's muscle shovel look front spoiler.
You are demented. that looks like a bloody tokyo high rise building. So does the top secret shit.
I should be in Brisbane for atleast one year; I am doing a transfer from the company in Dubai to the Australian head office in the CBD.
Looking for some new culture experience, which I'm sure Australia has plenty to offer.
I've been a long time reader of this forum, but have only signed up, can you point me into the right direction for the Tuesday night dinners? I wouldn't mind signing up for one.
Edited by Mr Kofi Ahmed
Looking for some new culture experience, which I’m sure Australia has plenty to offer.
I’ve been a long time reader of this forum, but have only signed up, can you point me into the right direction for the Tuesday night dinners? I wouldn’t mind signing up for one.
Look in the events section mate. It is posted there every week as to where we are going.
We will show you all the culture you could wish for. hehehe.
Dunno bout a front lip but you will get a fat lip if you keep this shit up.
rofl's
do u want me to pick that dummy up from the ground for you? :(
I am bring my wife and my son, however you can have neither.
dammit :ninja:
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
