Chance's of me dying on a 600 with said mods?
Well an 06 or 07 GSXR600 with exhaust and PC3 made (IIRC) 105rwhp. They weigh somewhere in the low 200kg bracket with you on it. Same as anything really, it's as dangerous as you make it :wave:
DAYYYYYYYYYUM!!!!
:drooly drools:
yeah get me some pics!! ha ha ha
hot without giving too much away is the hottest :ninja:
Karen's is teh sex!!
>_<
>_<
Reckon $15k will cover it?
Should do, I can't remember what the gixxer6 is worth by itself but you shouldn't have a problem picking up a second hand 04 or 05 for 12k or less (just be wary of bent/cracked frames), the PC3 last time I checked a while ago was around $800, tuned I think it was $1k, and the exhaust should be anything from $500 to $2000 depending on whether you want a slip-on or a full system, and what brand you go for. It's been a while since I've even been into a bike shop though so it might be best to check with them >_<
Cheers uncle Marc
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
